3/24/2022 9:48 AM | |
Joined: 3/24/2022 Last visit: 6/18/2024 Posts: 1 Rating: (0) |
After installing TIA Portal 16, I get the "Communication setting" window each time I start Windows. I have tried everything with no succed. Any idea? Thank you. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/24/2022 11:41:40New subject after splitting. |
3/30/2022 2:38 PM | |
Joined: 8/3/2009 Last visit: 9/24/2024 Posts: 13778 Rating: (1740)
Hello joseluisbm This FAQ is a few days old but still quite the same: https://support.industry.siemens.com/cs/de/en/view/25437381 You have to select a valid Ethernet Adapter and confirm the dialog. then it should be stored and the dialog should not popup at OS Start again. Bye Murof |
