12/23/2009 1:45 PM | |
Joined: 4/17/2009 Last visit: 8/9/2024 Posts: 303 Rating:
Hi Bemused, attached you will find an example with two possibilities of valve settings for SET. Finally you need values for this valve type. Please ask the manufacturer for this. Your SET-Team Attachmentbemused.zip (979 Downloads) |
SE Support |
1/5/2010 11:04 AM | |
Posts: 8 Rating:
Thank you for the example, it is a great help. The manufacture SMC says. The MTTF for the VP series is 24.6 million cycles. I have attached the data sheet from the manufacture. It seems to refer to 13849 not 62061. I would like to work in 62061 Can you help by extracting the relevent valve data. Attachmentold_VP357_$B!J_(BE_$B!K_(BVP300-SMN0005-A.pdf (782 Downloads) |
