8/30/2011 4:24 PM | |
Joined: 6/7/2010 Last visit: 7/9/2024 Posts: 571 Rating:
Hi , Attached is the user screen Created inside the Diagnostic page. For that you have to Enter the name Diag at Task 32 in regi.ini file. And in F drive in that dh file in that cus.dir file past this two files there. This is for your reference, you edit this file for your requirement. AttachmentUser screen.zip (862 Downloads) |
Regards, |
9/6/2011 9:03 AM | |
Hello, You need the all user screen to be out of Diagnosis page ? |
Regards, |
9/17/2011 4:10 PM | |
Joined: 9/17/2011 Last visit: 12/22/2020 Posts: 17 Rating:
you must notice the name of the com files,you can use the MA_JOG.com(in the JOG bag ) or use custom.com,just change the file name and then write some program PRESS(HS1) //M(WORK1/"开始对刀"//) PRESS(HS1) PRESS(VS8) //M(WORK2/"开始精磨"//) //M(WORK3/"开始光磨"//)
PRESS(VS8) |
12/2/2011 7:12 AM | |
Posts: 10 Rating:
见着亲人了,嘎嘎. |
