5/9/2022 10:35 PM | |
Joined: 9/21/2006 Last visit: 5/25/2023 Posts: 247 Rating: (63) |
TIA Portal can import & export the PLC tag table in several file formats. I recommend you export an existing set of tags to whichever file format works best for you, then examine how the tag definitions are formatted. Write your program to format tag definitions in the same way, then import the file you generate into your project. If you want to automate the whole process, check out the Openness API that can allow your program to tell TIA Portal to import/export tags, etc. without manual operations. SIMATIC TIA Portal Openness: API for automation of engineering workflows |
5/10/2022 9:06 AM | |
Joined: 8/24/2021 Last visit: 7/12/2022 Posts: 6 Rating: (1) |
Thank you very much for your response. I'll look into it. |
