4/7/2020 9:47 PM | |
Posts: 1 Rating: (0) |
Hello, I want to reset the OP177b mono to factory settings (update of the operating system), but the operation gives me the following error message please |
4/8/2020 3:41 PM | |
Joined: 8/3/2009 Last visit: 10/18/2024 Posts: 13982 Rating: (1760)
Hello do you have a PPI MM Cable (USB or RS232)? Here is the official FAQ with the Table where you can see which Cable you need: https://support.industry.siemens.com/cs/ww/en/view/19701610 This only works with this cable(s). Bye Murof |
Last edited by: Murof at: 04/08/2020 15:41:16If this Information really helps, you could use the Rate function |
