9/7/2012 9:22 PM | |
Posts: 2 Rating:
DEAR EXPERTS, I WILL APPRECIATE YOU IF ADDRESS ME THE LINKS TO FAIL SAFE & H PLCS DOCUMENTS IN PDF AND ETC. |
9/7/2012 9:45 PM | |
Joined: 9/27/2006 Last visit: 6/19/2024 Posts: 12260 Rating:
Hello H-Alaei; Here are a few links that should help you,... if you don't drown in the amount of information first: First: a Collection of documents on S7-400 redundancy PLCs: Manuals for S7-400H system For Industrial Safety, I recommend you start with the following document: SIMATIC Industrial Software Safety Engineering in SIMATIC S7 The attachment is taken from this link, and will help you decide which version of Safety Software you will choose for your application. Other manuals to complete your introduction to SiemensSafety Systems: SIMATIC Industrial Software S7 F/FH Systems - Configuring and Programming SIMATIC Industrial Software SIMATIC Safety - Configuring and Programming SIMATIC Industrial Software S7 Distributed Safety - configuring and programming S7 Distributed Safety Getting Started SIMATIC Automation System S7-300 ET 200M Distributed I/O Device Fail-safe signal modules Hope this helps, Daniel Chartier |
9/7/2012 10:19 PM | |
Posts: 2 Rating:
thanks so much. |
