10/31/2010 9:08 AM | |
Joined: 1/28/2009 Last visit: 9/10/2024 Posts: 6849 Rating: (1365) |
Hi Please check the attachment to check wether the values have been written some where in the program.follow the instruction to modify the value from program by inseting some small codes. Let me know if it is helpful best regards Attachment1.zip (201 Downloads) |
10/31/2010 12:35 PM | |
Posts: 3 Rating: (0) |
Finally it's working, you are right the values was changing conditionaly and used in other block Thanks a lot my friend Regards Octo |
11/3/2010 5:59 AM | |
Joined: 10/7/2005 Last visit: 10/6/2024 Posts: 3024 Rating: (1054)
Hello ELSAVAN in addition tohdhosseini's advise, I suggest you alsotick "Overlapping access to memory areas" in the "Go To Location" windowto see if your address pops up then. I hope this helps |
