6/24/2019 2:00 PM | |
Posts: 3 Rating:
Hello everybody, We have a costumer using the IoT2040 as a gateway between a S7 PLC and a server websocket. After an unexpected power off/on the SCLANACE XM400 has informed an error at the port where the IoT2040 was connected and the network performance was impacted. Only after remove the IoT2040 from the SCALANCE the network became stable again. Do you have some tip to prevent this kind of error? Attached you can see the flow, the event log, the nodes configurations and the network data collected by wireshardk after a power off/on of the module. AttachmentIoT2040_Diag.zip (101 Downloads) |
6/26/2019 8:54 PM | |
Posts: 3 Rating:
Thanks trinitry, I'll try it. |
