7/26/2021 8:05 PM | |
Joined: 7/12/2021 Last visit: 12/17/2021 Posts: 12 Rating: (1) |
Hey guys, I keep getting the errors "error in lower-level component" and "module exists. faulty. fault LED (SF)". I have attached the diagnostics buffer text. Background story, I had to remove a digital module from the program as I didn't physically have the extension module. Everything else (the cpu and the ai/aq) is/should be connected properly on my Siemens test stand. Thanks for the help AttachmentDiagnostics_TS.txt (435 Downloads) |
7/28/2021 5:21 PM | |
Unfortunately your suggestion didn't work. I appreciate your help/time nonetheless, Einstein. |
