8/21/2009 9:43 PM | |
Joined: 1/4/2008 Last visit: 6/19/2024 Posts: 703 Rating:
Hello, you can use the POINTER parameter for example like in this thread or try to search for the "indirect addressing" in the forum, you'll find many other threads. Also depends if you're using the STL or another language. For example in the SCL you can use the AT instruction for variable declaration to access a part of another one. Regards Sydney |
8/22/2009 2:44 AM | |
Posts: 138 Rating:
Dear you have provided a mysterious code. I even don't know which language is this. By the way i want to do the same thing in Ladder or FBD |
