6/2/2015 5:23 AM | |
Joined: 8/25/2006 Last visit: 9/12/2024 Posts: 2209 Rating: (278) |
Hello. It is not necessary to specify the rated field voltage in the drive. All defined by rated field current. |
6/2/2015 3:41 PM | |
Posts: 4 Rating: (0) |
Thank you again, Ok then there is not problem with the 90 volts specified it in DCM converter?
