6/24/2010 5:20 AM | |
Joined: 10/7/2005 Last visit: 7/15/2024 Posts: 3009 Rating: (1053)
Hello Pericles I wonder if you've seen the following from the "Application & Tools" section: "FIFO" for buffering measured values This (AVC chargeable) example may be exactly what you are after and would save you the "fun" of writing your own Block. I hope this helps |
Cheers |
6/24/2010 6:32 AM | |
Joined: 2/6/2009 Last visit: 6/18/2024 Posts: 939 Rating: (118) |
DEARPericles, You are right, The logic works with "BlockMov" instruction through indirect addressing. In one of my project I used the same method for "insert Step" and "Delete Step" operation and it works fine. My UDT name is Step, One Step (UDT) is having 32Bytes and I used 200 steps in my program DB. Revert back for any clarification.
_______________________________________________________________ |
