6/3/2016 11:56 AM | |
Joined: 7/20/2006 Last visit: 5/23/2024 Posts: 128 Rating: (8) |
Hi, Here you have code which should solve your problem, I atached source file of FB, so it's enough for you to compile and call FB. Important is that you should call FB only if value of your value which you'd like to recored is changed. TAR2
L P##i_array // move pointer to db area OPN DB [#t_db] LAR1 zero: NOP 0 end: NOP 0 regards Edek ps. just change extension of file to AWL AttachmentFB4.txt (187 Downloads) |
6/6/2016 9:39 AM | |
Posts: 4 Rating: (0) |
Hi I used youre solution and it is simple and working perfectly. thanks alot. Regards Kenni |
