11/1/2016 6:42 PM | |
Joined: 6/5/2015 Last visit: 12/12/2022 Posts: 2 Rating: (0) |
Ctrl+F is not working, I am using V5.5 sp3. when I press the Ctrl F gray out the window title bar, but is not opening the Find window. Need some help. ------------------------------------------------------------------------------------------ |
Last edited by: The Helping Hand at: 11/2/2016 2:18:13 PMNew subject after splitting |
11/2/2016 12:59 PM | |
Joined: 3/5/2014 Last visit: 8/5/2022 Posts: 5521 Rating: (1052) |
hi, have you tried the solutions that allready mentioned in this thread? Do you know following FAQ? In STEP 7, why can the "Find/Replace" dialog not be displayed in the LAD/STL/FBD editor? This FAQ can be easily found over search window in the upper rigth. hope this helps, regards, |
11/4/2016 9:04 PM | |
thanks for the advice. I try but still not working. I am using VM 11 window 7. |
11/5/2016 5:46 AM | |
Posts: 310 Rating: (18) |
Hello, What your going to Find ..?? If ur going to find Address in Programming Block means . U have to go for Cross Reference Option . Then only u have to Get all the Information about That .. Regards, Arasan. |
