10/29/2009 10:41 AM | |
Posts: 378 Rating:
Hello, i don´t know muich about these CPUs, but here i found somethin that maybe interesting for you http://support.automation.siemens.com/WW/view/en/2855123 On this side you can find this: If you should encounter problems during the operating system update... You can identify these CPUs as follows:
If you have one of the above problems, a Correction is available. This Correction procedure is also described on this side. I hope i could help you best regards bilao |
