5/1/2016 5:48 PM | |
Posts: 1 Rating: (0) |
Hallo, I have problem with S7-1211 6ES 211-1AE40-0XB0. My TIA V 12 profesional not support this CPU. Is upgrade SW TIA V12 SP1 for my buy CPU? Thanks. |
5/1/2016 5:51 PM | |
Posts: 8946 Rating: (999) |
For 1200 CPU with FW V4.x you need TIA V13, I'm afraid... |
5/1/2016 5:53 PM |
Posts: 198 Rating: (36) |
your cpu Hardware version v4 so need to install Tia Portal v13 here is link to download tia portal v13 SIMATIC STEP 7 (TIA Portal) V13 TRIAL Download install and enjoy it. |
5/2/2016 6:25 AM | |
Joined: 5/28/2008 Last visit: 8/6/2024 Posts: 4515 Rating: (838) |
Hello Steve, First of All, the correct Part number of your CPU is 6ES7 211-1AE40-0XB0. Firmware Version V4.1 released for S7-1200 CPUs
So, the best solution for you is to upgrade Step 7 TIA V12 to TIA V13 SP1 __________________________ But also we have to take the following points into consideration. As your CPU "6ES7 211-1AE40-0XB0" is CPU 1211C V4.1, Please see this link: Information about successor product. and that old CPU "6ES7 211-1AE31-0XB0" can be programmed using Step 7 V11 SP2 or higher. Please if you tried my suggestion, feedback us. Hope this helps. |
3/23/2018 8:52 AM | |
Joined: 6/19/2017 Last visit: 8/5/2024 Posts: 8175 Rating: (169) |
New question published by Debajyoti is split to a separate thread with the subject phase out time or life cycle of S7 1200 and S7 1500 controller. Best regards |
