7/7/2010 7:33 AM | |
Joined: 9/18/2006 Last visit: 8/9/2024 Posts: 591 Rating:
Hi. In documentation "FM 354 Servo Drive Positioning Module" 6ES7 354-1AH01-8BG0: When connecting an incremental encoder, please note that at the instant of the zero pulse (TRUE signal) the signals of tracks A and B must also be TRUE. If necessary, the negated signal must be connected and, consequently, the direction adjusted (MD19). “1” signal >= 2.4 V “0” signal < 0.8 V Probably it will help you. Best regards. AttachmentConnecting the drive unit.pdf (153 Downloads) |
7/7/2010 1:32 PM | |
Hi. There can be it to you will help. https://www.automation.siemens.com/doconweb/showpdf.asp?HTTPS=REDIR&item=17481&cd=sinumerik_simodrive_04_2010_e&scope=all&ResultSet=17615&CurrentItem=17615&ResultType=content https://www.automation.siemens.com/doconweb/showpdf.asp?HTTPS=REDIR&item=17481&cd=sinumerik_simodrive_04_2010_e&scope=all&ResultSet=17751&CurrentItem=17751&ResultType=content Best regards. |
