1/14/2011 9:47 AM | |
Joined: 4/22/2010 Last visit: 5/3/2024 Posts: 5697 Rating:
Yes that can be done, you need a resistor (2k2 will do), connect it between +24VDC and your NPN output of the sensor. Test without PLC first. Attached some paint art Edit: forgot to mention that the signal will be inverted, maybe that is a problem. Edit 2: found this http://shop.di-soric.de/shop/productgroup/productgroupREADAction.do?artbtext=%28907%2C84%2C0%29+%28941%2C84%2C0%29&showProductOnly=%28907%2C84%2C0%29+%28941%2C84%2C0%29&artb=%28943%2C84%2C0%29 |
Last edited by: Marcjan at: 1/14/2011 12:08 PMLast edited by: Marcjan at: 1/14/2011 10:01 AMProblem solved? |
