8/25/2015 9:50 AM | |
Joined: 8/7/2013 Last visit: 7/12/2024 Posts: 9 Rating:
Can anyone confirm that FreeFilesSync is working with WinCC 7.3, I had tried but I got error related to running SQL server. Thanks ------------------------------------------------------------------------------------------ |
Last edited by: Xanax at: 8/25/2015 9:51:32 AMLast edited by: Min_Moderator at: 8/25/2015 1:25:21 PMNew subject after splitting |
8/28/2015 9:53 AM | |
Joined: 10/3/2010 Last visit: 7/5/2024 Posts: 1556 Rating:
I used Hobocopy in the past and it worked just fine. Since discovering FreeFileSync, I use this instead and it also works perfect for backup running WinCC-projects and it is more comfortable to use. If it doesn't work for you, you need to check its settings (Tools-Options). The other options will also work but are just commercial alternatives. By the way, I know that several Siemens employees also use Hobocopy & FreeFileSync instead of commercial tools ;-) |
B r g d s , |
