11/13/2014 10:24 AM | |
Joined: 11/21/2007 Last visit: 7/7/2024 Posts: 2325 Rating:
Hello Suryamuni Things to Check : a) What type of batteries are you using ? - Original SIEMENS or any other ? b) If Original Siemens - What is the Order No & mAH Rating b) if Not Original - whay is the Battery Make , Model and mAH rating c) Does the System remain powered off for lomg durations ? d) What are the cards installed in the S7-400 Rack ? - PS / CPU / CPs etc Hope this helps Cheers Navnag |
There is no such thing as the last bug in a program |
7/10/2017 10:48 AM | |
Joined: 3/2/2007 Last visit: 7/26/2024 Posts: 932 Rating:
Kindly, how did you solve this problem " Frequent Cpu Battery Failure " ? Thank you |
... thank you ... |
