11/21/2020 9:50 AM | |
Joined: 5/11/2020 Last visit: 1/2/2024 Posts: 8 Rating:
Dear all, I want to make an application that two G120X drives controlling two pumps as a pressure booster. the sequence is attached. the problem is that in Vaccon Drive there is a communication between the drives and can be controlled without a plc with a preset configuration inside the drive which I can't find anything similar at siemens G120X. Attachmentmulti-pump multi-drive.zip (201 Downloads) |
11/22/2020 2:13 PM | |
Joined: 3/27/2008 Last visit: 7/15/2024 Posts: 1123 Rating:
Tractor |
