11/30/2017 9:09 AM | |
Posts: 40 Rating: (1) |
Hi, I installed the node-red-contrib-modbus with globally. I deployed the Flow1 attached in this post, same problem. The error info. is given below. *************************************************************** 30 Nov 15:59:21 - [info] Server now running at http://127.0.0.1:1880/ 30 Nov 15:59:21 - [info] Starting flows 30 Nov 15:59:21 - [info] Started flows 30 Nov 15:59:21 - [info] serial port /dev/ttyS0 opened at 115200 baud 8N1 30 Nov 16:04:25 - [info] Stopping modified flows 30 Nov 16:04:25 - [info] serial port /dev/ttyS0 closed 30 Nov 16:04:25 - [info] Stopped modified flows 30 Nov 16:04:25 - [info] Starting modified flows 30 Nov 16:04:25 - [info] Started modified flows 30 Nov 16:04:28 - [red] Uncaught Exception: 30 Nov 16:04:28 - Error: Could not locate the bindings file. Tried: → /usr/lib/node_modules/node-red-contrib-modbus/node_modules/serialport/build/serialport.node → /usr/lib/node_modules/node-red-contrib-modbus/node_modules/serialport/build/Debug/serialport.node → /usr/lib/node_modules/node-red-contrib-modbus/node_modules/serialport/build/Release/serialport.node → /usr/lib/node_modules/node-red-contrib-modbus/node_modules/serialport/out/Debug/serialport.node → /usr/lib/node_modules/node-red-contrib-modbus/node_modules/serialport/Debug/serialport.node → /usr/lib/node_modules/node-red-contrib-modbus/node_modules/serialport/out/Release/serialport.node → /usr/lib/node_modules/node-red-contrib-modbus/node_modules/serialport/Release/serialport.node → /usr/lib/node_modules/node-red-contrib-modbus/node_modules/serialport/build/default/serialport.node → /usr/lib/node_modules/node-red-contrib-modbus/node_modules/serialport/compiled/6.9.2/linux/ia32/serialport.node at bindings (/usr/lib/node_modules/node-red-contrib-modbus/node_modules/bindings/bindings.js:93:9) at Object.<anonymous> (/usr/lib/node_modules/node-red-contrib-modbus/node_modules/serialport/lib/bindings/linux.js:2:36) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) at Function.Module._load (module.js:438:3) at Module.require (module.js:497:17) at require (internal/module.js:20:19) at Object.<anonymous> (/usr/lib/node_modules/node-red-contrib-modbus/node_modules/serialport/lib/bindings/auto-detect.js:16:22) at Module._compile (module.js:570:32) at Object.Module._extensions..js (module.js:579:10) at Module.load (module.js:487:32) at tryModuleLoad (module.js:446:12) at Function.Module._load (module.js:438:3) at Module.require (module.js:497:17) ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/30/2017 1:08:59 PMNew subject after splitting |
11/30/2017 1:11 PM | |
Joined: 6/19/2017 Last visit: 6/28/2024 Posts: 8176 Rating: (169) |
Closed cause question posted twice.
