3/2/2016 3:35 PM | |
Posts: 26 Rating:
If these products were purchased from the Buffalo Grove factory there are a couple of things you should do 1. Log a call with Technical Support 8008777545. 2. Tech support will try to understand and help troubleshoot the issue. 3. Return any parts under warranty to the Buffalo Grove Return center with an RMA. on the RMA note that you require a trouble report as to why these actuators may not be working after a short time. If you need more help you can contact me at jon.elling@siemens.com |
