11/29/2006 1:22 PM | |
Joined: 10/19/2005 Last visit: 11/30/2020 Posts: 1611 Rating:
Hi, which version of WinCC flexible did you use? Notes: For ProAgent you need WinCC flexible SP1and HF3 At this time it gives the HF5! => http://support.automation.siemens.com/WW/view/en/24104401 After then, if you open a new project, then you should have the "Diagnostic" folder. Greetings, |
7/25/2012 9:26 PM | |
Posts: 1 Rating:
Samsy, did you get any answer about this? Thank you!
7/26/2012 1:13 PM | |
Posts: 3037 Rating:
Hello, I have found this example for ProAgent. Process diagnostics with SIMATIC S7-PDIAG and ProAgent based on LAD/FBD/STL and S7-GRAPH Tweety |
