11/19/2021 4:47 PM | |
Joined: 9/27/2006 Last visit: 6/27/2024 Posts: 12264 Rating:
Hello Carmine; To connect your PAC 3200 to a Profibus netwok, you need the following Profibus expansion module mounted on the energy meter: 7KM9300-0AB01-0AA0. See the screenshot below. The gsd file for a PAC 3200 only exists for this module. If you already have it, the gsd file can be found here: - GSD files for expansion module PAC Profibus DPV4.1, 7KM9300-0AB01-0AA0 https://support.industry.siemens.com/cs/ww/en/view/109773345 If you need more information on how to install, configure commission and program the data exchange with your PLC, look at the following document: https://support.industry.siemens.com/cs/ww/en/view/26504372/130083101195 Hope this helps, Daniel Chartier |
11/22/2021 9:00 AM | |
Joined: 11/17/2021 Last visit: 11/22/2021 Posts: 2 Rating:
Thanks. But I need the gsd for model 3220. I already have the 3200. We are working in profinet. |
11/22/2021 12:08 PM | |
Hello Varmine; It makes our help more efficient if you ask precise questions. From ypur original post, how could we détermine you are working with Profinet? A gsd file is required for Profibus networks, for Profinet you need a gsdml file: https://support.industry.siemens.com/cs/ww/en/view/109772403 Daniel Chartier |
11/13/2023 4:55 AM | |
Joined: 6/22/2021 Last visit: 6/20/2024 Posts: 1 Rating:
楼主要的是3220,你给的是3200 会不会看题 |
11/13/2023 4:57 AM | |
Joined: 6/19/2017 Last visit: 6/28/2024 Posts: 8193 Rating:
Hello xu1356, Please try to discuss your question in English language. This is an international community, and we try to focus on one language. Posting in English will help you to get more response to your question. This is the translation of your question:
Regards, |
11/13/2023 5:05 AM | |
Joined: 6/27/2017 Last visit: 6/26/2024 Posts: 158 Rating:
Hello xu1356, did you open the links and read them? |
4/12/2024 11:14 AM | |
Hi, maybe following FAQ helps you: |
