8/4/2024 3:56 PM | |
Joined: 8/18/2023 Last visit: 8/20/2024 Posts: 2 Rating:
Hi all,
thanks ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 08/05/2024 11:10:43New subject after splitting |
8/5/2024 11:18 AM | |
Joined: 7/9/2015 Last visit: 8/30/2024 Posts: 3943 Rating:
Hi, Your post is a little short on information but perhaps this is where you are looking for: Combined configuration with WinCC (TIA Portal) and STEP 7 V5.x or Combined configuration with WinCC (TIA Portal) and STEP 7 (TIA Portel) in separate projects (Video)There you find GSD/GSDML files for Comfort Panel and Mobile Panel (2nd generation) Regards, Towome |
8/6/2024 9:41 AM | |
Joined: 8/3/2009 Last visit: 9/12/2024 Posts: 13653 Rating:
Hello AutoGen_1770025 for what do you nead the GSDML file for a Comfort Panel? The files that are available are only made for direct keys configuration. If you only want to communicate to the panel with HMI connection with s7 protocol you will not need toinsert the Panel to the HW config of a PLC. But if you give us a few more information, perhaps we can answer Bye Murof |
8/19/2024 10:41 AM | |
