9/18/2012 9:14 PM | |
Joined: 9/27/2006 Last visit: 9/10/2024 Posts: 12282 Rating:
Hello eli; The warning from the following FAQ should give you the answer to that question: How do you configure a fault-tolerant S7 connection for a user application via Industrial Ethernet with the SIMATIC NET PC software? Warning: Fault-tolerant S7 connections are available only for CP1613 and CP1623. It is not possible to use standard network cards in this case. Hope this helps, Daniel Chartier |
