8/14/2006 10:14 AM | |
Posts: 28 Rating:
Thanks Late, Here's the GSD. AttachmentConsiSafe.zip (301 Downloads) |
9/11/2006 7:22 AM | |
Posts: 2348 Rating:
Description
http://www.comsoft.de/html/icpe/profibus/switch/prs.htm#technical
GSD file - in attachement
AttachmentCOMS0A49.zip (318 Downloads) |
7/9/2008 12:07 PM | |
Posts: 1 Rating:
COMSOFT- PRS - PROFIBUS DP Master Redundancy Switch We are switching between S5 and Siemens TDC and have the problem that the TDC does not recognise (if rebooted) the PRS - PROFIBUS DP Master Redundancy Switch unless we either diconnect the profibus plug from the PRS or switch off the supply of the PRS. Used Communication Processor in TDC CP50M1 Can you please forward me the modified GSD file. Mine is the: ;=========================================================================== ; GSD-File for DP-Slave PRS ; Manufacturer: ; Rev: V1.0 ; Author: Jens Fichtner 2006 ; Revised: ; 1.00 31.05.2006 Initial ;=========================================================================== AttachmentPSR_SNIFF.zip (286 Downloads) |
Last edited by: PammerR at: 7/10/2008 10:10 AMLast edited by: PammerR at: 7/10/2008 10:10 AM |
