9/29/2022 1:09 PM | |
Joined: 1/21/2013 Last visit: 10/9/2024 Posts: 3170 Rating: (491)
Hi soodeh.f, the engineering licenses are usually backward compatible. The licenses for STEP 7 definitely are. For SIMATIC STEP 7 Professional V17 you can use a "normal" license which will be valid for STEP 7 V11 (the 1st released version of STEP 7 Professional) up to V17. In addition, there is a "Combo" license. This license also allows the usage of the STEP 7 V5.x. The linked licenses are for the basic software with delivery type "Download". If you already have some licenses, you maybe can buy an upgrade. And please ask your customer, which additional software you will need. There are a lot of other products which will also need some license. Kind regards |
9/30/2022 7:41 AM | |
Joined: 7/9/2015 Last visit: 10/9/2024 Posts: 3966 Rating: (591)
Hi, for further informations about licenses please check this FAQ: Which license do you need to upgrade from STEP 7 version V5.x, V11 ... V16 to the TIA Portal V17?Regards, Towome |
