4/23/2020 9:33 AM | |
Joined: 4/28/2015 Last visit: 9/9/2024 Posts: 3345 Rating: (379)
Hi, you can check this application example: https://support.industry.siemens.com/tf/ww/en/posts/162549/. Best regards! |
Not working for IOT2050 support anymore from March 1st, 2024. |
4/23/2020 4:19 PM | |
Posts: 11 Rating: (0) |
thank you for your answer! but do i need IOT2040 to send data ti ibm waston or there is another way with mqtt please |
4/23/2020 4:23 PM | |
Hi, there are also mqtt client function blocks for S7-1200/S7-1500. With that you need no gateway to talk mqtt. https://support.industry.siemens.com/cs/ww/en/view/109748872 Best regards! |
4/23/2020 5:19 PM | |
Joined: 9/27/2006 Last visit: 10/17/2024 Posts: 12289 Rating: (2687) |
Hello alaa; I have not connected a S7-1200 to IBM Watson directly, but maybe these links can help you: - first, a way to connect a S7-1200 through MQTT to Mindsphere (the Cloud): "LMindConn_MQTT" library for S7-1500 CPUs and S7-1200 CPUs https://support.industry.siemens.com/cs/ww/en/view/109772284 - next, details on MQTT connectivity from IBM Watson: IBM Knowledge Center, IBM Watson IOTPlatform, MQTT connectivity for devices https://www.ibm.com/support/knowledgecenter/SSQP8H/iot/platform/devices/mqtt.html Combining these two constructs should provide a lot of good hints for your project, if you add this Slideshare document: https://www.slideshare.net/DMCChicago/pushing-data-from-s71200-to-cloud Hope this helps, Daniel Chartier |
4/23/2020 5:40 PM | |
thank you so much Mr Daniel Chartier for your answer .. |
4/23/2020 6:15 PM | |
can any one help with the MQTT in tia portal please and how it connect to IBM watson.. |
