8/23/2011 9:06 AM | |
Posts: 1 Rating:
I have also faced same type of problem many time.. All the time module was corrupted, it seems same in your case also. |
8/25/2011 4:32 PM | |
Posts: 74 Rating:
Hello wong_arif, the SM422 have designed internal electronical circuits by following points. Try to measure voltage on load (in cable tray could be short circuit to another voltage) and load impedance. In attachment You have datasheet of mentioned driver, according this you can find answer. AttachmentBSP450.pdf (155 Downloads) |
