7/3/2019 8:22 PM | |
Joined: 9/27/2006 Last visit: 7/7/2024 Posts: 12268 Rating:
Hello Christian; I am not a specialist of Siemens low-voltage equipment, but I may have found an interesting link for your search, in the Siemens Industry Mall (electronic catalog): https://mall.industry.siemens.com/mall/en/WW/Catalog/Products/10019024?activeTab=product The product you are looking for is referred to as a Door-coupling rotary operating mechanisms, complete; it is actually a combination of various elements, the molded-case circuit breaker, the extended shaft, the door rotary switch... so you should contact your nearest Siemens rep to have them help configure all the necessary parts. Notice that the 3VL9-xxx circuit breakers are in the process of being replaced by catalog numbers 3AV_-___, so really you must use the contact search shown in the link to locate your nearest low-voltage rep. Hope this helps, Daniel Chartier |
