6/30/2016 3:33 AM | |
Posts: 21 Rating: (0) |
not connect to |
6/30/2016 3:36 AM | |
no connect to |
6/30/2016 6:45 PM | |
Joined: 9/19/2009 Last visit: 5/11/2024 Posts: 458 Rating: (82) |
Hi Please, check the following directory C:\Program Files\Siemens\WinCC\diagnose Here, you will find a file with the name of your drivers and the logs. See what is the number of your error code, and post it. |
If my answer help you, use the Thanks or Rate Button, It is free of charge :-) |
7/1/2016 4:01 AM | |
i don't understand what happened?when i install kepware and it working,then i uninstall kepware and it working,i think it lack of file |
7/1/2016 11:09 AM | |
