6/13/2019 10:42 AM | |
Joined: 12/9/2010 Last visit: 10/8/2022 Posts: 623 Rating:
Hi j13s, 1. The called block in first row may not be properly compiled. Share the text in red. 2. For UC or unconditional call, no parameter are passed. FB can not be used. 3. The remaining STL code is required to understand logic. Pointer can't be understood with this info. |
If you like the comment, rate it (right top) or thank it (left bottom). |
