4/23/2012 10:56 AM | |
Joined: 12/1/2009 Last visit: 10/27/2024 Posts: 672 Rating: (147) |
Dear nandgate, I would say that this question is not so easy to answer, while it it pending on your application andthe type ofencoder used. Generally it is possible toprocessencoder input signals. Eitheroninternal (compact) CPU's or with external function modules (i.e. FM350-1) on other CPU's. What you shouldverify is that the input module can handle your encoder signal. A quick look atboth specs. will tell you. Regards. |
Give us your feedback and show us your respect! |
4/25/2012 8:49 AM | |
Dear nandgate, please check out the S7-300 compact CPU's with onboard High-Speed-Counter (HSC) orexternal counter module for S7-300. Alternativlyit's worth to checkout the S7-1200as well. You can't beat the pricewith a S7-300. A link to the available CPU's is here: https://eb.automation.siemens.com/goos/catalog/Pages/ProductData.aspx?catalogRegion=WW&language=en&nodeid=10045649&tree=CatalogTree®ionUrl=/#topAnch&activetab=product& Regards. |
12/19/2016 5:09 PM | |
Joined: 9/3/2014 Last visit: 3/13/2019 Posts: 4766 Rating: (122) |
New question published by JigneshD is split to a separate thread with the subject How can i get a pulse in program?. Best regards |
