11/16/2016 3:45 PM | |
Joined: 8/3/2009 Last visit: 8/15/2024 Posts: 13561 Rating:
Hello bits_n_bytes I think this FAQ is made for your case: https://support.industry.siemens.com/cs/ww/en/view/34230359 It is a little bit older but I Think you could use it also for TIA Portal instead of WinCC flexible. Bye Murof |
11/17/2016 12:05 PM | |
Joined: 6/22/2009 Last visit: 5/24/2024 Posts: 62 Rating:
Yes. I understand this is the case. Thanks a lot. I will modify my design. |
