4/1/2024 9:59 AM | |
Joined: 2/12/2024 Last visit: 7/26/2024 Posts: 5 Rating:
Hello I have same problem but my progress of restoration didn't reach 50% (I forgot the percentage) and now my HMI cannot read the image file in my USB stick (the image file found as not compatible). Any idea for this? thank you for your help. ------------------------------------------------------------------------------------------ |
Last edited by: AutoGen_3579592 at: 04/01/2024 11:03:44Last edited by: AutoGen_3579592 at: 04/01/2024 11:04:23Last edited by: Jen_Moderator at: 04/02/2024 08:22:17New subject after splitting |
4/2/2024 11:38 AM | |
Joined: 5/6/2022 Last visit: 7/30/2024 Posts: 436 Rating:
The manual defines the requirements to be able to update the image version of the panel. I share the link below: "SIMATIC HMI HMI devices Comfort Panels: Updating the operating system" Have you tried other USBs to see if the same thing happens with all of them? Have you tried resetting the panel to factory settings and then testing again to see if it detects the files? Best regards! |
