6/2/2014 4:12 PM | |
Joined: 7/2/2008 Last visit: 5/29/2024 Posts: 928 Rating: (306) |
Hellohoshen, To the best of my knowledge, the sm@rt access should have been enabled as a runtime service in the WinCC flexible project. As long as you don't have the project file, you won't be able to enable the sm@rt access. I hope someone else will have a solution. Best regards, H-H
6/2/2014 4:44 PM | |
Posts: 559 Rating: (87) |
You have to create the new backup of HMI from the process. That's the only solution. |
6/2/2014 6:09 PM | |
Joined: 6/7/2013 Last visit: 5/24/2024 Posts: 11 Rating: (0) |
Thank you!! I have seen an option of "MiniWeb" to control an HMI panel. Is this an option? eli
6/2/2014 8:08 PM | |
Thank you all for the help. I will create a new mp277 & eventualy it will work. eli
6/2/2014 8:27 PM |
Posts: 59 Rating: (2) |
Good Job.That was the only solution. |
