8/15/2018 12:32 PM | |
Posts: 3609 Rating:
Import of a question of the user ericksen85
8/15/2018 2:03 PM | |
Joined: 8/3/2009 Last visit: 8/15/2024 Posts: 13561 Rating:
Hello Look in the Technical Data of the TP1200 comfort https://support.industry.siemens.com/cs/de/en/pv/6AV2124-0MC01-0AX0/td?dl=en It should work with S7200, also in TIA Portal you can define a S7200 Connection, I tried it. Bye Murof |
