3/26/2013 6:43 PM | |
Joined: 9/27/2006 Last visit: 9/26/2024 Posts: 12283 Rating: (2685) |
Hello Sukusugu; If your panel supports scripts, you could use the "change connectons" script to change the active redundant CPU. If it does not support scripts, you would have to use a hardware solution, as explained in the following FAQ: How do you connect a panel to a SIMATIC H station? Hope this helps, Daniel Chartier |
3/27/2013 5:39 PM | |
Posts: 23 Rating: (0) |
Hi, TP 1500 Comfort Panel support redundancy??? I am using TIA portal, Script is not possible in TP 1500.. Help me Reagrds, Sukumar.T |
3/28/2013 9:58 AM | |
Posts: 3037 Rating: (192)
Hello, What do you use now? WinCC flexible or WinCC TIA Portal? Which panel do you use? You can use scripts with TP1200 Comfort. What are the functional differences between the different SIMATIC panels? Tweety |
3/28/2013 8:41 PM | |
Hello Sugu; Could you please provide us wiuth the exact part numbers of the panels you are working with? Basic panels do not support scripting, but comfort panels do... Hope this helps, Daniel Chartier Attachment40227286_PanelCompare.zip (290 Downloads) |
Last edited by: O_Moderator at: 4/2/2013 8:56 AMLast edited by: dchartier at: 3/29/2013 1:09 AM |
