10/19/2020 4:02 PM | |
Joined: 8/3/2009 Last visit: 5/17/2024 Posts: 12970 Rating: (1651)
Hello do you have tried to install the latest Upd ? https://support.industry.siemens.com/cs/de/en/view/109763890 Does it crash also with a new Project with the same Panel type? Bye Murof |
10/19/2020 10:59 PM | |
Joined: 1/6/2009 Last visit: 4/12/2024 Posts: 132 Rating: (2) |
Hello Murof, Thanks for your message. Meanwhile I spot the problem. It was a conflict between the main screen and other screen. Because I'm "calling" both at same time and runtime collapse. Its a "programming" error that pass in compiling. Best regards, Nuno |
