1/6/2013 5:41 PM | |
Joined: 3/21/2006 Last visit: 10/7/2024 Posts: 10229 Rating: (1181)
Try it HMI Selection ToolI hope you will find the good panel fro your application. P.S. Use IE in order to start that tool. Best regards, Hristo Mihalev
1/6/2013 6:20 PM | |
Joined: 9/27/2006 Last visit: 10/15/2024 Posts: 12289 Rating: (2686) |
Hello kour; Besides the selection tool, you could look at the HMI panels borchure: https://www.automation.siemens.com/salesmaterial-as/brochure/en/brochure_panels_en.pdf?HTTPS=REDIR You could look at this model, for example: However the input voltage required for such a panel is 24 VDC. You would require a DC-DC converter, such as the following model from Siemens, or one from another manufacturer: Hope this helps, |
1/7/2013 12:12 AM | |
Posts: 13 Rating: (0) |
Thx |
