5/4/2017 3:11 PM | |
Joined: 9/27/2006 Last visit: 9/18/2024 Posts: 12282 Rating: (2684)
Hello asmar; This Temposonic sensor acts as a SSI, RS422 encoder. You need a SSI input module to read it. The selection of the module you need depends on the CPU you have. For a S7-300 (Et 200M) you could use a SM 338. Ultrasonic Position Encoding Module SM 338 ... - Siemens Support For a S7-1500 you could look at a ET 200SP Technology module TM PosInput 1. Hope this helps, Daniel Chartier |
3/26/2018 2:22 PM | |
Posts: 3 Rating: (0) |
I was looking for same solution on temposonic sensors |
