2/21/2024 3:52 PM | |
Joined: 7/19/2022 Last visit: 6/21/2024 Posts: 370 Rating: (61) |
Hello redsky_tr, In the Step 7 manual, page 233: SIMATIC Programming with STEP 7 V5.5 you can see how to copy a library from one PC to another. This way, you can take the library to your Step 7 installation on your PG and use these blocks. |
