1/20/2017 8:03 AM | |
Joined: 8/3/2009 Last visit: 7/29/2024 Posts: 13392 Rating:
Hello Wormus You can use the SmartTags Object.
dim test ' writing SmartTags("Tagname") = 10 'reading test = SmartTags("Tagname") Message Box and Inputbox are disabled, look here: https://support.industry.siemens.com/cs/de/en/view/57132412 Perhaps you could use the File Explorer Solution out of the Toolbox: https://support.industry.siemens.com/cs/de/en/view/106226404 Bye Murof |
1/20/2017 11:07 AM | |
Posts: 102 Rating:
thanks alot . solve. |
