3/5/2009 9:49 AM | |
Joined: 4/24/2006 Last visit: 4/26/2024 Posts: 8616 Rating: (1147) |
Dear sundar, You will need cable 6XV1 440-2KH32. Here is manual: http://support.automation.siemens.com/WW/view/en/1137086 When you look in appendix E, page E-10, you will find lay out of cable. Best regards, Wizard |
3/5/2009 9:52 AM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating: (1181) |
Hello Look at C Technical Data OP17 (page 167). regards |
3/18/2009 12:56 PM | |
Posts: 100 Rating: (2) |
Thanks. I am using op17/DP model num (6av3 617-1jc20-0ax1) version 1.03. I download the program using protocol software version 6.0 (COM: 1; BAUD RATE: 38400). The program downloads to OP17/DP without any error. But when I upload the program using same configuration its showing error. I attached the snapshot below. Attachmentop17.zip (1515 Downloads) |
