1/25/2020 2:42 PM | |
Joined: 6/24/2018 Last visit: 9/15/2023 Posts: 3 Rating: (0) |
hello my friend your post was was very important to me because i am facing the same problem . can you pleas tell me how did you take the GSD file from the old program and installed it in the new on if you can add some picture our short video it will be very helpful . ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 01/27/2020 11:28:11New subject after splitting |
1/28/2020 3:56 PM | |
Joined: 9/27/2006 Last visit: 4/28/2024 Posts: 12257 Rating: (2665) |
Hello luay; If the gsd file was integrated in the old project you can find it in the program files on your programming PC. You will find the path to the gsd directory in this link: https://support.industry.siemens.com/cs/us/en/view/2383630 Locate the file you need (you can open the file in Notepad to make sure which Profibus slave the file corresponds to), copy the contents and paste it in a text file which you will rename as a *.gsd file, and integrate it into your new project; or simply copy the file to the adequate \s7data\gsd directory in your new project. Hope this helps, |
