12/9/2018 1:12 PM | |
Posts: 4 Rating: (0) |
Hi, i tried to run a 3g connection with a PCIE Huawei module with ppp and wvdial. When all is right configurated I will start an connection test I bekome an error. > The PPP daemon has died: Pty program error (exit code = 9) messages log: Dec 8 16:04:06 localhost pppd[2866]: pppd 2.4.5 started by root, uid 0 Dec 8 16:04:06 localhost pppd[2866]: Using interface ppp0 Dec 8 16:04:06 localhost pppd[2866]: Connect: ppp0 <--> /dev/ttyACM0 Dec 8 16:04:06 localhost pppd[2866]: CHAP authentication succeeded: Congratulations! Dec 8 16:04:06 localhost pppd[2866]: CHAP authentication succeeded Dec 8 16:04:06 localhost pppd[2866]: kernel does not support PPP filtering Dec 8 16:04:36 localhost pppd[2866]: IPCP: timeout sending Config-Requests Dec 8 16:04:36 localhost pppd[2866]: Connection terminated. Dec 8 16:04:36 localhost pppd[2866]: Exit. Dec 8 16:04:06 localhost pppd[2866]: kernel does not support PPP filtering I think this will be the problem. How can i install/aktivate the PPP filtering support? Thanks. Tim ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/10/2018 12:39:36 PMNew subject after splitting |
12/23/2018 1:52 PM | |
that was why i postedt my question to the thread . thanks for your help :) Tim |
12/25/2018 2:18 PM | |
Joined: 6/19/2017 Last visit: 5/2/2024 Posts: 7987 Rating: (163) |
Closed cause question posted twice. The second thread with the subject Debian for IOT2000 is published within the conference IOT2000: News, Tutorials, Applications, FAQs. Best regards Jen_Moderator |
