12/21/2021 12:51 AM | |
Joined: 12/13/2021 Last visit: 1/3/2022 Posts: 23 Rating:
[snip] Let me just ask another quick question - how can I write to analog output from several places (for instance if I would like to change same analog output from several steps) ? Thanks in advance, regards. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/21/2021 12:51:38New subject after splitting. Division of question into separate topics. |
12/21/2021 9:14 AM | |
Joined: 6/11/2019 Last visit: 8/5/2024 Posts: 2207 Rating:
To do this, you use the Mux module and switch it over according to the program steps. |
1/3/2022 3:24 PM | |
Joined: 6/3/2013 Last visit: 4/8/2024 Posts: 50 Rating:
First, create a SCALE instruction for output manipulate. If your program is based on step, then ONLY ONE step is active at a time. Therefore, each step can handle the same scaling instruction without conflicting logic.
And you will know the truth, and the truth will set you free. |
