1/2/2020 9:51 PM | |
Joined: 3/14/2018 Last visit: 6/20/2024 Posts: 32 Rating: (3) |
Another attachment the script in VBS |
1/6/2020 11:52 AM | |
Joined: 10/3/2010 Last visit: 9/30/2024 Posts: 1562 Rating: (192) |
Should work, just tried in V7.4 Did you check for possible global script runtime errors? If not, insert a a smart object in your pdl: Smart objects -> Application Window -> Global Script -> GSC Diagnostics |
B r g d s , |
1/8/2020 10:12 AM | |
Please try a similar script in a normal pdl. It's probably an issue between vbscript and faceplate (fpt) |
B r g d s , |
1/8/2020 1:20 PM | |
Posts: 41 Rating: (4) |
Strange, it works for me on v7.5. I've attached the pictures, hopefully they can be of use. Just add the internal tag xxx_Int as 16-bit and you can test. Goodluck AttachmentPics.zip (340 Downloads) |
